Coolant Question Help Please
Old Jul 7, 2009 | 04:27 AM
929-kid's Avatar
Default Coolant Question Help Please
Hey,
I haven't mess with a motorcycle coolant before but the other day i was riding and stop at walmart and saw coolant coming out of the overflow tube. I check the cap on the radiator and still see that the spring in the cap is still working and the rubber seems to be fine. I switch the coolant. But i notice when the engine is hot, the rad hose would not be pressurize and can still be squeeze, but it would still cool down once the e-fan kicks on. Could it just be that the cap is not working well. If i not mistaken then there should be at least 16lb of pressure in the cooling system unless the cooling system is different from a car. Any help would be nice.
Thanks
Old Jul 11, 2009 | 12:35 AM
chasesdaddy01's Avatar
what temp is your fan kickin on?
Old Jul 12, 2009 | 01:59 AM
929-kid's Avatar
the fan kicks on about 215 F. and the temp will go down once the e fan kick on. but my main question is that does the radiator hose ever get hard like when there pressure in the system. The weird thing on my 929 right now is that their would seem to be no pressure in the system but it still cool down like it should.
Old Jul 12, 2009 | 04:06 PM
fade's Avatar
No the hose should not be hard if it was hard then you would have an issue
Da11en47
Apr 26, 2009 11:42 AM
Napalm1000
Mar 19, 2009 02:14 PM
Ruthless
Apr 27, 2008 09:19 AM
urandaman
Jul 15, 2007 07:17 AM
corrcullen
Jan 21, 2007 06:31 PM
