Clutch problems and downshifting
Old Jan 24, 2009 | 11:13 AM
Sladkixxx's Avatar
Registered Users
Default Clutch problems and downshifting
OK, here is the problem: when im in 1st gear and im sqeezing the clutch lever my bike is still moving forward(kind of like its in friction point even though the clutch is squeezed all the way), also when i try to downshift from second into neutral or to 1st, i need to press really hard or sometimes it doesnt even let me. It wasnt ever doing it before. PLease feel free to tell your thoughts, thank you
Old Jan 24, 2009 | 02:28 PM
929 RR CBR's Avatar
Default RE: Clutch problems and downshifting
sounds like you might need to adjust the slack out of your clutch cable, you can do this right up on the left clip on where it goes into the clutch lever, tun the screw counter clockwise until you get the slack out, but you want to leave a little slack or you will burn your clutch up. if that dosent help it might need a new clutch
Old Jan 24, 2009 | 03:25 PM
Sladkixxx's Avatar
Registered Users
YeahYeah i did that and now I have like no friction zone almost at all any other thoughts, thank you for the reply though
Old Jan 25, 2009 | 08:32 PM
929 RR CBR's Avatar
sounds like the clutch then, ive seen some bikes do this if the clutchsprings get too hot, but if your saying that you adjusted it and its still fd up then it probably need a clutch
Old Jan 26, 2009 | 08:15 AM
packdog's Avatar
i would def. suggest tearing into the clutch to inspect and measure plates. you may have a broken plate causing the stick. I'd be very hesitant to ride until inspected. shouldn't take you more than an hour and you don't even need to drain the oil if you put it on her side. you could also have a failing lift lever (not on your handle bars, but the twisting bit inside the clutch cover plate.)
Old Jan 26, 2009 | 10:27 AM
HAVOC's Avatar
it could be something as simple as the clutch rod that hooks to your clutch cable. mine snapped on my last 929 while riding preventing me from down shifting. it was starting to fail on me and i would be at a stop light , pull in the clutch (have it in 1st gear) and she would pull forward, just enough for me to feel that something wasnt right.
pull off your clutch cover and make sure your clutch rod is in the correct position to pull the pin on the clutch plates. if it isnt that could be whats causing the problem... or your clutch could be bad.. or you have a worn out clutch cable..
Old Jan 30, 2009 | 05:42 PM
Sladkixxx's Avatar
Registered Users
Thank you
Old Jan 31, 2009 | 07:22 AM
showerslll@yahoo.com's Avatar
there is a recall on late 2000 and 2001 models 929 tthe clutch start to come apart at high speed or somthing i would have the VIN ran at a dealership to see if its been done befor u go teasring into things the recall is posted in one of these fourms
Old Jan 31, 2009 | 01:03 PM
Sladkixxx's Avatar
Registered Users
Hehe, already did that, they say my VIN does not apply, thank you though
Old Feb 1, 2009 | 12:39 PM
labkreationz's Avatar
where can i get more info on the recall? i searche dit but didnt find anythng.
