Clutch Issue...
Old Dec 22, 2008 | 10:50 PM
hon00cbr929's Avatar
Default Clutch Issue...
I have a question about my clutch assembly. The problem that I am having with the clutch is that I can shift in to 1st and 2nd gear but I can't get passed that. Does anyone have any clue on what it could be and what part that I need to replace???
Old Dec 23, 2008 | 05:11 AM
hellboytt's Avatar
Default RE: Clutch Issue...
sounds like a trans and not the clutch
Old Dec 23, 2008 | 05:14 AM
TheX's Avatar
Definitely sounds like a tranny issue (no, not the cross dressing kind).
Old Dec 23, 2008 | 06:04 AM
94cbr600kid's Avatar
abcdef
Old Dec 23, 2008 | 11:07 AM
Honda4Ever's Avatar
You need your shift forks adjusted. Don't think it can be done without splitting the cases but don't quote me on that.
Old Dec 23, 2008 | 12:23 PM
ORIGINAL: Honda4Ever
+1 Exactly what i was thinking..possiable you bent your shift Forks..IT happens..but yea you gotta split the case
Old Dec 23, 2008 | 11:36 PM
Honda4Ever's Avatar
Yhea I adjusted them in my 1000f this summer when I went thru the engine. Its very simple once you've got her guts all laid out on the table. Here is a tip I can pass along to everyone. If you happen to to have your shift forks out give them a special little treat and debur any sharp edges on the end of the fork. Next take a heatgun and warm the forks up to @ 150 degrees and dip the ends in some Moly Grease. [Use the Hi-Temp stuff] Once they are cool wipe off any excess. The moly will penatrate the steel down into the pores of the metal and never come out. It makes for some very smooth shifting. I've logged about 2000 mi since doing this and it still shifts silky smooth. Hey man its winter get yourself a good manual and get busy. Its winter and you can't really ride much anyway. I've got the 954 torn apart now, she is gettin some go-fast goodies this Christmas. can't wait for spring.
Old Dec 24, 2008 | 12:14 PM
RCR's Avatar
RCR
after 2nd you have to up shift agian for therd[:@]J/k
Did you try shifting it into the other gears sitting in the garage turned off? and what does it do? act like it shifts(meaning lever moves like it should)or does it lock up?
Old Dec 29, 2008 | 08:17 AM
xXx's Avatar
xXx
How smooths are your gear changes guys.
When i shift in to 1st its a bit clunky and same with 2nd from then on its ok is this normal??
Old Dec 29, 2008 | 08:34 AM
TheX's Avatar
ORIGINAL: 94cbr600kid
abcdef
Really? Tell us more.
