clock won't stop blinking
ok i can set my clock on the bike and then when i turn the bike off and then back on it has resets itself and then some time i can set it and it will be ok for a few hours then it reset itself again to 1:00 and is flashing good fuse????????????????? WHERE CAN I START ON THIS ONE
RE: clock won't stop blinking
^Doubtfull about the fuses, possible, but I doubt it.
There is obviously a loosed/bad connection somewhere. Pull your fairings and start inspecting wires.
Anything else happen when you loose your clock? Loose gauges at all? RPM's drop? Idle drop? Having any problems starting? When did you replace the battery and why?
First thing I would do is check the BOTH rectifier plugs to ensure they are properly connected. I had a similar issue and it eventually drained my new battery. Luckily I found it before it killed my $127 battery. If both plugs are connected, then remove your fairings and start checking connections.
Good luck, keep us posted.
everything works ok besides the clock it has done the blinking scense i got it in jan this year the stator and rectifier plug as been cut off when i got it so i wired toghether and soder them and the battery was old and it took a s%$t when i charged it so i got a new one like every thing else on this money pit lol someone said it could be the cluster going out it is the second one the first one was broke this one has 36 k and the bike has 12k on title and the moter has 50miles on it after i rebult it ?????
Mine does the same thing, but it was in a wreck previously. I had to splice the connection between the gauge cluster and the main harness, so maybe it is a wire in there. I'll have to check the diagram when I get home tomarrow, but wonder if it's like a car radio with a constant hot line to save the clock/settingsand a trigger to power up everything only when the IGN is on. If that's the case, I'll jump +12 to that wire and test mine to see if it works and get back to you.
