cleaning the chain
Old 12-03-2011, 02:52 AM
stealthCBR929's Avatar
Official Glory Detailer
Default cleaning the chain
sup guys what should i used to clean my chain?
Old 12-03-2011, 09:05 AM
Trey929RR's Avatar
I use some "White Lightning" chain cleaning spray and a little elbow grease, but my bike sits out in the elements with a cover on. I did use a "honda" type chain cleaner, worked like a charm but it was $10 a can and it removed any dirt/grime on the chain/sprocket/swingarm. Basically anything anywhere(didn't try paint ).
No experience with WD-40 but my neighbor uses it on his chain and has never had a complaint.
Old 12-03-2011, 11:30 AM
cBrentb's Avatar
you can use wd-40 to clean and lube it. it will not hurt the o rings. its does a good job. i use it weekly and take towel and clean off excess. every few weeks i use the chain wax from honda. it stays longer and is less messy
Old 12-04-2011, 02:36 PM
Monkeybutt2000's Avatar
Yup,either wd40 or kerosene. A grunge brush and either of these and your chain will be like new. I've done this for a long time and never had any issues. Don't use a chain lube either.
Old 12-04-2011, 02:47 PM
sj66's Avatar
Seen some nasty photo's of people cleaning chain with the back wheel rotating don't do that 10 fingers are handy
Old 12-04-2011, 06:02 PM
gotcbr's Avatar
WD40 + GrungeBrush & red shop towel to clean. Followed by quality chain lube such as Pro Honda HP w/ Moly, PJ1, Belray, Motul, Motorex, etc.
Old 12-04-2011, 06:08 PM
volcom440's Avatar
Old 12-04-2011, 08:05 PM
Trey929RR's Avatar
Grime Minister Chain Brush - Universal Parts & Accessories Can pick it up just 5.99. Just like "the grunge brush" but just a different company.. from Cycle Gear
Old 12-05-2011, 12:46 AM
thanks guys for the advice! i have an extra can of pj1 o ring chain lube and a ton of wd 40
Old 12-07-2011, 11:35 PM
what kind of chain did honda put on the 929 stock? my bike has a DID end less gold chain and i have to drill it out to take it off to clean . i might keep my brothers off his 54 its an EK chain
Quick Reply: cleaning the chain
