changing 929 plugs
i took the airbox off and went through the top, use the tool that came in your tool kit to remove the plugs. took me around an hour to change mine. the sparkplug placement is one of my few complaints with the 929. good luck
after you get the plugs loose, go buy some fuel hose about 1/8" inside diameter.....u can use this to push down on top of the plugs and pull them out and get them started w/the new ones......i found it to work great....
ORIGINAL: johndoe
954 swingarm conversion. the 954 swingarm is still uneven but it does take spools and imo looks better
ORIGINAL: ibkevman
I have a beef with the uneven swingarm and no threads from factory for spools. still havent figured out how I'm going to take care of that.
ORIGINAL: johndoe
ORIGINAL: ibkevman
ORIGINAL: johndoe
929 spool installation
