Changed sparkplugs-Bike not running right
So I just changed out the plugs. After Iput it all back together and started it up it would hardly run unless I twisted the throttle a little. I also have a continous red light and F1 on. Could it possibly be that one of the coils aren't on all the way? Help!!!
RE: Changed sparkplugs-Bike not running right
Which method did you use to changed the plugs? From the top via moving the tank, air box, etc. or by the manual remove the radiator and so on? If you did it from the tank like I did you might have pinched a gas line when putting the tank back on. I would go back and check all your work, check all electrical connections air temp sensor, coil harnesess, gas lines. Wouldn't hurt to check all fuses while the seat is off.
supersnake83
07-05-2009 01:56 AM
