cam pulse sensor
Old Apr 2, 2008 | 01:38 PM
  #31
shizz's Avatar
Default RE: cam pulse sensor pics now
ok i got it to kick over a bit act like it wanted to start all i did was plug these holes on the bodies i think they go to the wax valve starting valves ? heres a pic does any body know any thing about them
Old Apr 2, 2008 | 06:01 PM
  #32
bravehart's Avatar
you can get a set of injectors/throttle bodies pretty cheap off ebay if you wanna try some new ones. have you been running it with the airbox lid off?
Old Apr 2, 2008 | 08:06 PM
  #33
shizz's Avatar
yes but the sensor ar still hooked up
Old Apr 3, 2008 | 07:39 AM
  #34
sc929's Avatar
if the inj. leakdown it will you won't see it unless the assembly point is leaky. I've seen that but didn't create a no run problem. Very minimal. If they don't seat the fuel will leak off in the intake tract and run down on the valve. If the valve is open, on into the cyl. wetting the plugs. The pulse width(open time) of the injector is created by the compt(map). The injector will have a spring inside it to close it when there is no juice on it. It is not a reverse polarity type deal, like a pwr window, its either on or off. I have never had my 9 down further then plugs so I am not sure, just making a guessfrom past experiences with cars and other bikes. Think about these things, you established it's a rich condition, so that leaves,compt creating wrong pulse width, injectors not closing, regulator not allowing return. Sure some of those metal shavings didn't get in the fuel line. Has anyone ever messed with the bike before, ie changing the fuel system(inj), for bigger ones. That could possibly work if you knew exactly what to do with the pc3.
Old Apr 3, 2008 | 10:00 AM
  #35
shizz's Avatar
the metal shaving were raped around the end of the pump by the strainer? I dont know what to do with this bike
Old Apr 3, 2008 | 10:17 PM
  #36
bravehart's Avatar
ORIGINAL: shizz
yes but i dont think it would be able to read air flow with no lid because there would be no vacuum inside the airbox
Old Apr 4, 2008 | 06:25 AM
  #37
shizz's Avatar
it ran before without lid on and sensors ???????? and the vacum line from the map sensor is hooked up andifthe temp and map sensor are not hooked up it has default settings im going to do a comp check today just to see who know that could be a problem
Old Apr 4, 2008 | 07:20 AM
  #38
Evan's Avatar
Did you run it w/o the sensors hooked up?
Old Apr 4, 2008 | 04:27 PM
  #39
shizz's Avatar
no ,at first i had the air box to the side then i took them out of the air box and hooked them up for more room
Old Apr 4, 2008 | 06:58 PM
  #40
bravehart's Avatar
where do you live? im in cincinnati.
