Busted Lower Crankcase
Old Nov 2, 2006 | 02:08 AM
Nate's Avatar
Default Busted Lower Crankcase
Wussup everybody. I lowsided my 01 929. Busted the stator cover and put a hole in the lower half crankcase. Just curious if anyone could tell me where I could find a used lower crankcase. Any info would be great. Thanks, Nate.
Old Nov 2, 2006 | 04:25 PM
thesaint's Avatar
Default RE: Busted Lower Crankcase
similar thing happened to my bike, when i bought it, the stator cover and part of the crank case was busted. i spent a long time looking for a crank case, but then a bunch of motorcycle shops were pointing me towards machining shops to get it welded and the bolt holes retapped. $110 later, she's good as new, might be worth looking around at some machine shops in your neighborhood.
Old Nov 3, 2006 | 02:09 AM
QuinC's Avatar
same thing here.. but i bought it that way and they tried to j.b weld it.. then i droped it and busted out the jb weld.. ended up making a rubber plug out of high temp stuff not just any rubber.. used silicone and the stator cover to hold it in place. hasent leaked yet! good idea about the machine shop 110 aint bad.
Old Nov 3, 2006 | 02:08 PM
Nate's Avatar
Yeah, I tried the jb weld thing to. Didn't work, still leaked. I'll take the machine shop advice and buy a a cage for this damn bike. [sm=icon_cheers.gif]
Old Nov 3, 2006 | 03:29 PM
Nate's Avatar
Question for thesaint. What exactly did they do at the machine shop? Did they fabricate a peice and weld it in or what? Just curious. Thanx, Nate.
Old Nov 4, 2006 | 04:53 PM
eye toke's Avatar
had mine welded worked great. you will need a , m, 20, 1.5 right hand thread bolt. to pull rotor off. drain oil, remove rad hoses, pull battery, un hook computer. for safety,make sure it goes to a metal fabrication, and welding, shop, or aircraft welder. good luck
[IMG]local://upfiles/7134/2C8B07ECDB9C4ECC85E282A98A93AD46.jpg[/IMG]
Old Nov 6, 2006 | 10:20 AM
thesaint's Avatar
From what he told me, he had to heat up the crank case, and he tig (dont know if i spelled that right) weld the crank case in the broken spot, he built up the broken spot, grinding it into shape after each weld. Then he had to tap a new bolt hole, and it was done, i can upload some pictures if you would like, i just have the after shots, but u can see what he has done.
waddleboy
Sep 12, 2011 07:27 PM
jaynd
Sep 16, 2008 11:28 PM
rray12288
Jul 7, 2008 12:31 PM
Sproutf3
Apr 2, 2007 02:34 PM
