bumble bee won't start again
the bike ran fine last night this morning it didn’t wont to stay idling then the pos wont fire just sit and crank, it has gas the fuel pump is working, it is in neutral, the kill switch is in the run position, I’ve tried it with the kickstand up, and the clutch pulled in, I guess I’m going to look at the spark plugs tonight but I’ve had it with this bike its a new problem every week, there cant be too much more I need to replace before its a new bike. Does anyone have any ideals?
RE: bumble bee won't start again
fuel pressure could be low
clutch switch/ kickstand switch could be bad or disconnected, try bypassing
sparkplugs fouled
i had a bad cam pulse sensor once, i had a fit trying to figure out why the bike would start
the bike has obd, the manual willtell you how to use it
try a little starting fluidin the air ram duct and see what it does
sparkplugs fouled
ORIGINAL: bravehart
sparkplugs fouled
sparkplugs fouled
ORIGINAL: shizz
what is obd and if the cam pulse sensor is bad would it get spark
o.b.d. (on board dianostic) it can tell you of certain problems with your bike. its in the manual under emissions i believe. ithink if your bikes running it will flash a code (red light on cluster) if you have a problem, if it wont start you can jump two wires under the seat and it will cause the red light on the gauge cluster to flash a code. you can find out what the codes are and what wire to jump in the manual (please read it in detail before you try it). i used it to find out my c.p.s. was bad, other than that i would have waisted time and money replacing other parts.
