bike wont start please help.
Old Jan 28, 2006 | 09:25 PM
syko9's Avatar
Default bike wont start please help.
I am having trouble starting my bike. The problem is that when I hit the starter button all it does is make a clicking sound. I had to lay my bike down a couple of days ago and I messed up my stator cover. I replaced my stator cover and changed the oil. I am stumped to why it won't start. I charged the battery because the clock reset and that still didn't work. If anyone has any clue to why it won't start please let me know thanks. Oh and its a 2001 honda 929rr
Old Jan 29, 2006 | 12:57 AM
QuinC's Avatar
Default RE: bike wont start please help.
i downloaded a book off emule for the 2000 929 and it says:
ENGINE DOES NOT START OR IS HARD TO START
Possible cause
Faulty fuel pump (Section 5) 1 . Check for operation of the fuel pump
Normal
2 . Inspect the fuel flow
I
Normal
3 . Inspect the fuel injector
I
Normal
4 .1 erform a spark test
Good spark
5 . Test cylinder compression
Compression normal
6. Starting following normal procedure
Engine does not start
7 . Remove and inspect spark plug
22. TROUBLESHOOTING
Abnormal
Abnormal
Abnormal
Low compression
Engine starts but stops
Wet plug
Faulty pressure regulator (~ection 5)
See section 5
Weak or no spark
• Faulty spark plug
Fouled spark plug
Faulty ECM
Broken or shorted spark plug wire
Faulty ignition switch
Faulty ignition pulse generator
Faulty engine stop switch
Loose or disconnected ignition
system wires
Valve stuck open
Worn cylinder and piston ring
Damaged cylinder head gasket
Seized valve
Improper valve timing
Improper starter valve operation
Intake pipe leaking
*Improper ignition timing (Faulty
ignition coil or ignition pulse generator)
Fuel contaminated
• Starter valve closed
*Throttle valve open
Clogged air cleaner
let me know if you need anymore info out of the book.
Old Jan 30, 2006 | 10:31 AM
syko9's Avatar
Thanks for the info I printed out the page and will take the bike apart and try to see if any of those things are the problem.
And I pushed started my bike yesterday to get it running and it worked. I had it running and everything seemed fine when it was on. I don't think its the spark plugs. I rode it around for about an hour and all the power was still there and the bike seemed fine. I shut it off after an hour and tried to restart but it did not kick on.
Old Jan 30, 2006 | 03:28 PM
QuinC's Avatar
maybe your starter then? also will it start with the charger still on the battery?
Old Jan 30, 2006 | 07:41 PM
sixs929's Avatar
Gotta be the start system. (The successful push start is the key.) Also don't forget the start solenoid - can't remember for sure, but I believe it's under the seat. Good luck.
Old Jan 30, 2006 | 08:00 PM
syko9's Avatar
No the bike won't start with the charger on I tried that. I think it is my start solenoid. It is clicking like hell. I checked everything else. Air filter clean. spark plugs good. The start solenoid is under the seat behind the battery and it is doing a fast click when i try to start it. Thanks for the help.
Old Jan 30, 2006 | 08:22 PM
QuinC's Avatar
you need or what any info out the book? i can look to see if there is a way to test it. or post a picture of a diagram of it. let me know.
Old Jan 30, 2006 | 08:39 PM
QuinC's Avatar
http://cgi.ebay.com/ebaymotors/Honda...08163589QQrdZ1
Old Jan 31, 2006 | 03:41 PM
syko9's Avatar
Thanks quinc that was helpful. I will replace the starter solenoid and see if that works. If you have any more info i would appreciate it. thank you.
Old Jan 31, 2006 | 04:16 PM
QuinC's Avatar
do you have the fireblade parts manual? if not give me your email and i'll send it to you.
