Bad stator or rectifier?
Old Jun 13, 2010 | 10:52 PM
scaredem23's Avatar
Question Bad stator or rectifier?
so i tested the resistance on the stator plug like the manual said and it was between .6 and .7. The continuity test from each yellow wire to ground read 002. Don't quite know what that means but the meter manual said that as long as its below 30 ohms it would beep and it did. So does that mean the stator is bad? This is the part i don't understand also, the manual says to check for battery voltage from the red/white wire to ground. Where is this red/white wire, i don't c any red/white wires coming from the stator or the rec. Is there anything i can test on the rec while its disconnected from the bike? I took it out and its not burned or anything
MegatronousPrime
F2 For Sale / Trade / Wanted
Sep 30, 2010 02:20 PM
tjuvi
Jun 14, 2010 03:56 PM
Goloth
May 21, 2010 01:51 PM
TripsD
Sep 20, 2007 08:07 PM
JIrvin
Aug 26, 2006 03:39 AM
