954 swingarm conversion
Old Oct 2, 2008 | 10:00 PM
yeller929's Avatar
Default 954 swingarm conversion
Getting ready to convert my bike to a 954 swingarm. Got the brake bracket, shock mount plates and swingarm. Cleaned and greased all bearings. From those who have done it, what did you use to take off the main pivot bolt, you know the one that take a 24mm hex tool to remove? Anything else to look for? Did you have to remove the pipe?[/align]
Old Oct 3, 2008 | 01:42 PM
vwmaniacvr6's Avatar
Default RE: 954 swingarm conversion
Go to the hardware store and get a bolt with a 24mm head, buy a nut as well and weld it on the end. That's how I made the tool for $5. If you don't have a welder or a friend with one, take it to a muffler shop with $5-10 cash and somebody will take the 30sec to do it.
Old Oct 4, 2008 | 06:58 AM
country1430's Avatar
If you don't have a welder, just buy two nuts and put them on the bolt together and tighten them up. The outsidenut will lock the inside nut and viceversa, It will hold just as good as a welded one.
Old Oct 4, 2008 | 02:16 PM
yeller929's Avatar
ORIGINAL: vwmaniacvr6
Did it and it works perfectly!! Thanks!
Old Oct 16, 2008 | 11:58 AM
01929er's Avatar
LOL this is what i did as well when i pulled my motor...good times to see great minds think a like
Benjy68
Apr 26, 2014 07:08 PM
Yin-Yang
Apr 6, 2014 10:51 AM
madmansilvia
May 19, 2012 10:47 AM
knonfs
Feb 14, 2011 06:48 PM
