954 engine in a 929
I'm definitely interested in trying this, I have found a motor locally and I definitely have the skillset to make it happen, but before I purchase the engine I want to confirm that I can do this with only the 929 electronics. the firing order is the same and everything? I have read that the 954 injectors have a different harness plug, but that is irrelevant if you reuse the 929 throttle bodies. i would assume that if you use the 929 electronics then the relocation of the bank angle sensor is irrelevant because your not using the 954 harness. any help is definitely appreciated, i am new to bikes but have tons of experience modifying fuel injected honda cars and think that most of my skills will cross over. thanks in advance...![Icon Confused](https://cbrforum.com/forum/images/smilies/icon_confused.gif)
Oh, I have full intentions of getting a full dyno tune so please don't flame me about the tune being wrong.
i agree back doc im swaping the harness all the electrical and engine in to my 29 after the engine is done . the case is cracked on the 54 engine so im going to tig weld it and get her all fixed up . i need to get a 54 cluster too . for now im going to run my 29 engine i just hooked up the power comander and o2 sensor eliminator plug tonight bike seems to have a bog off the line but after that seem to rev and run good i couldent find a map for a shorty so i ran a map for hindle high mount exhaust and stock air filter . im going to get a custom map done in a month or soo
its a easy swap if you have what you need. if your going to use the stock 929 tank you need to use the 929 air box because the 54 air box is shaped different. if you use the 929 ITBs on a 954 motor then you will need to retune the bike other wise it will most likely blow up. so to do the swap you need cluster, ecu, full harness. and you will have no problems.
