929 won't run
929 won't run
Hello I have a 2000 929 that I'm working on , it ran before winter , someone cut the kill switch wires and the ignition wires , I fixed all the wires I found cut , all the switches are working but the fuel pump will not turn on , tested pump and it works , tested computer in another bike and it works , changed all relays , checked and changed lean sensor , changed all four wire harnesses and gauges , checked all fuses and grounds and still nothing , I did not change stator , rectifier , crank or cam sensors , I'm stumped / lost please help
