929 with no spark
Old Jan 5, 2014 | 02:56 PM
jkjel15's Avatar
New question: there is about 11.7 volts at the coils with ignition on and this drops to about 9.5 volts when cranking. Is this normal/ is this enough volts to produce a spark? Manual says the voltage should jump to about 100 volts?
Old Jan 6, 2014 | 03:15 PM
jkjel15's Avatar
Originally Posted by 74demon
You need to use a noid light, or equivalent, to see if your fuel injectors are firing. The 12v power and pulse signals at the injectors are the same circuits as the coils.
I looked down the throttle bodies with a flashlight and the injectors are not firing either. Fuel pump is priming though. Injectors test out ok and have battery voltage power to them which drops to around 10 volts when cranking just like the coils. Why wouldn't either the coils or injectors fire when they have power to them?
Old Jan 6, 2014 | 07:19 PM
74demon's Avatar
They both have constant power to them. The ECM uses cam and crank signals to fire them by grounding the circuits to fire each at the right time.
Is your ECM grounds all good?
Just out of curiosity, do you have 9v at the pink wire at the back of the ignition switch?
Old Jan 7, 2014 | 03:51 PM
jkjel15's Avatar
ECM had continuity to ground when I checked. I have battery voltage on the pink wire at the ECM but not sure at the ignition switch, I will check. Would the cam sensor giving a low voltage cause the ECM not to ground the circuits? When I test the cam sensor it only reads about .5 volts max but mostly in the .2-.3 range when the manual states it should be >.7 volts minimum. I tried using a different cam sensor and still got the same reading. I do not have a peak voltage adapter like the manual states but when I test the ignition pulse generator it tests out fine at 1.1 volts using the same method. I have a feeling this is where my problem is but I don't know what would cause the cam sensor to give low volts other than the cam sensor itself?
Old Jan 7, 2014 | 03:56 PM
74demon's Avatar
The pink wire must have 9v. There is a resistor on the bottom of the switch that reduces it. If the ECM doesn't see ONLY 9v, it won't fire the coils or injectors. It's a security feature to prevent it bike from being hotwired easily.
I don't think that it's discussed in the manual either.
Old Jan 7, 2014 | 08:55 PM
jkjel15's Avatar
Are you talking about a HISS equipped bike? Because if you are mine is not HISS equipped. I will check it out though just in case your not.
Old Jan 7, 2014 | 09:00 PM
74demon's Avatar
HISS is an entire different monster. Glad we don't have it.
Old Jan 8, 2014 | 12:40 PM
jkjel15's Avatar
Well I checked the pink wire and I am getting 12v at both the ignition switch and ECM, not 9v like you said I should. Is it safe to say that this is where my problem is? Is the resistor replaceable?
Old Jan 8, 2014 | 12:57 PM
74demon's Avatar
I think you may have found it!
The resistor is built into the switch. If you're good with that sort of thing, you could try. If you do get a new switch, stay away from the ebay china ones. They don't work either.
Old Jan 9, 2014 | 03:04 PM
jkjel15's Avatar
Thanks 74Demon you are a lifesaver! I hooked a 9 volt battery up to that wire just to see if it was the problem and what do you know it fired right up. I also found out that my original ECM was bad as well as the bike will only start with the known good one I acquired during the troubleshooting process. I can't believe Honda doesn't mention anything about this wire or the resistor in their manual. Do you know what type/size of resistor or diode that I could splice in that would accomplish the same job as the original one? Was reading in some other posts that a 2.2k ohm resistor would work but I tried that and it didn't seem to drop the volts at all. I couldn't appreciate your help more!
