929 cuts out while riding and dash lights go out
Old Feb 1, 2013 | 09:09 AM
74demon's Avatar
Originally Posted by blade929
Hi all.
I have had a look at my bike at the things you have recommended ,and it seems that it is the key, if i start it up and then wiggle the key a little bit it cuts out and loose display, how can i resolve this matter?????
Replace your ignition switch.
Old Feb 1, 2013 | 12:07 PM
blade929's Avatar
Registered Users
Thanks demon.
Is it an easy job to replace the ignition switch? and do i need to get it programmed to the ecu?
Many Thanks
Old Feb 1, 2013 | 12:43 PM
74demon's Avatar
Thanks demon.
Many Thanks
It's not too difficult. I'd remove the top triple clam to make accessing it easier.
No programming needed. Just get a good quality part. It must have the correct diode in it, or it the bike will not start.
Old Feb 1, 2013 | 12:56 PM
blade929's Avatar
Registered Users
It has hiss security fitted. does that still apply?
Or could i replace the barrel and put the chip in the new keys from my old keys?
Old Feb 1, 2013 | 01:07 PM
74demon's Avatar
Replacement is the same, but I'm not sure about programming. I didn't realize you were in the UK and have the HISS system. Our bikes in the US didn't come with that, so I've never played with the system. I'll see what I can find out...
(Put your location in your info (User CP))
Old Feb 1, 2013 | 01:11 PM
blade929's Avatar
Registered Users
thank you demon. very much appreciated
Old Feb 1, 2013 | 03:22 PM
Conrice's Avatar
new lockset
Old Feb 1, 2013 | 03:26 PM
Conrice's Avatar
whoops, looks like i'm a lil late to the party....
from a little searching - it seems that you'll need the ECM, lockset, and HISS all from the same bike.....
it'd probably be easier to take your ignition to a locksmith and have them fix the problem.... they can take your ignition apart and replace/repair what's loose (even with it being electrical). they are many electrical locks and what not these days.
you'll have to drill out the screws that hold it in place from the top tree though....
some (other people on other forums) said honda dealers do offer that kind of service - but it'd cost $1500 to replace the whole thing
Old Feb 1, 2013 | 03:42 PM
74demon's Avatar
I searched too and came up with a result of replacing the entire system.
I'm not sure how exactly the system works, but what you're after is the electrical part of the switch. That's the part that's failing, not necessarily the key and tumbler part. If the electrical part can be had separately, and the HISS system only matches the key/ecm, you may get away with not doing the entire system. But I can't seem to find any info on the system to be sure.
Old Feb 9, 2013 | 08:15 PM
sj66's Avatar
The transponder reads a magnetic signal from the key so it would not matter if the key is loose as it does not need to touch.
I would check the wiring to the hiss that is around the key
It sounds like a bad earth I will have a look and see what I can find on the bottom of the hiss as I have a spare ecu/transponder and all the other ****
