929 Cooling Fan Shutting Off
Before i start spending money, I'm just curious if it's the temp switch or the fan motor going bad. The fan was wired up by the previous owner to turn on with the ignition and run all the time. When I 1st turn the bike on the fan runs full tilt, no issues. After 15- 20 mins, the fan will turn VERY slowly and just shut down completely. I noticed this after watching my temp climb from 190 to 230 inside of a few minutes. I shut her down, turned the key, I heard the fuel pump prime, but no fan. Checked all the connections and all seems ok. After a few mins, the fan would then turn really slow. 5-10 minutes later, I turn the key to check the temp.....175 and the fan is running full tilt? Go figure. Seems like the motor might be on its way out and is crapping out when it gets hot? I also removed the lead from the temp sensor and grounded it when it was hot and got nothing from the fan. What do you guys think?
As it turns out, the motor must have been going bad as I replaced it over a week ago and it hasn't shut off since. Wound up using a fan from an 08 600rr so the brackets were different. Just took them both apart and swapped the new motor and fan blade into my old bracket. So if anyone wanted to do this, YES they will work. I was a little concerned at 1st being the 600 fan was only HALF as deep as my original fan so there is a 1 inch or so gap between the fan and radiator. I was surprised cause this thing flows just as much air as the original if not more. It's been cool out, but my temp hasn't gone past 209 degrees yet. We'll see.....engine ice may be coming next...
Wow, thanks Stealth, definitely good to know. If that's the case, I'll be putting it back stock for sure. I just gotta unravel the electrical tape and see exactly what was done. I think he just grounded the temp sensor wire
Yeah...PO grounded the fan because he's too lazy to replace a $28 fan switch which is located on the bottom of radiator to the left (when you sitting on bike).
Bypassing is temporary...
Order the fan switch...remove the old one, install the new one. Flush radiator and put in new coolant while you are at it.......you may need to crimp a new connect head to the ground wire (that the PO grounded) likely he splice that already
