2001 CBR 929 Fighter build
Well for anybody who missed my post in the noobies thread, my winter project has begun. I picked up this 2001 CBR 929 with less than 7000kms...dirt cheap... It was missing most of its fairings which gave me the desire to build my second streetfighter.
My first one was a 1997 Suzuki Bandit 600. It was very light and nimble, and after modifying the carb set-up to a gsxr set-up and throwing a short stack on I was able to get up to 242kmph. However it lacked bottom end. I made the mistake of trading it for a 1997 Honda Civic and I definately got the short end of the stick on that one. As of right now the 929 has received new vortex clip-ons, a new vortex front master, a 58 tooth rear sprocket, a shortened yoshi pipe, and an acerbis headlight. I have removed the crash cage since the last picture (a real heat-score to have in this city). My immediate goals are to fit an R6 tail section, polish the frame, and paint the remaining body gloss black. My new digital cluster is on its way and I guess I'll figure out the best way to mount it when it arives as my current set-up doesn't allow for much room (stay has been removed and headlight is fork-mounted). I'll do my best to keep you all updated with my progress and I'll try to pack this full of pictures ;) If you have an suggestions let me know, I'm quite open to new ideas! [IMG]local://upfiles/30934/F8DC0A4C9E834C128AF5A500705DC8D2.jpg[/IMG] |
RE: 2001 CBR 929 Fighter build
ORIGINAL: murray195 As of right now the 929 has received new vortex clip-ons, a new vortex front master, a 58 tooth rear sprocket, a shortened yoshi pipe, and an acerbis headlight. I have removed the crash cage since the last picture (a real heat-score to have in this city). My immediate goals are to fit an R6 tail section, polish the frame, and paint the remaining body gloss black. My new digital cluster is on its way and I guess I'll figure out the best way to mount it when it arives as my current set-up doesn't allow for much room (stay has been removed and headlight is fork-mounted). [IMG]local://upfiles/30934/F8DC0A4C9E834C128AF5A500705DC8D2.jpg[/IMG] So what you're saying... is you want my bike? lol. I like your taste! Hey, you should check this out for your top triple mount. http://www.hoheydesigns.com/honda/929954.html Will fit your vortex clips, and also be able to convert to DBB later. or... You can throw a 7/8 short bar thru the DBB mounts and mount your instrument cluster to that, while still using your clip-ons. Best of both worlds. Also, I found that using the rubber boots on the Acerbis gave me very little room to route all the wiring, clutch cable, hb cable, front brake lines, damper and whatnot... so I used some parts from Ace and Home Depot to step the headling assembly out just a little bit. Worked great... so if you want to use that idea I can send you pics of the parts I used, and how it looks. Here's a pic of mine... I put a list of my mods by catagory after the pic. So might give you some more ideas. - Pixel - http://img182.imageshack.us/img182/5...9081020zq1.jpg http://img205.imageshack.us/img205/5...4081833nw3.jpg http://img525.imageshack.us/img525/6...4081826ir9.jpg STUNT: OMR Subcage FTW! Freestyle Ingenuity Crash Cage Freestyle Ingenuity 12 o'clock Bar Freestyle Ingenuity Dirt Bike Bar Riser Kit Inverted SE Carmichael Dirt Bike Bars Custom Instrument Bracket Mount For DBB Risers Brembo 16x18 Hand Brake HoHey Designs Dual Caliper Setup For Hand Brake / Rear Brake MSR Pro Raptor EZ Pull Clutch (Cut To 1 Finger Length) Custom Length Clutch Cable Thrust Sprockets -1 / +13 (15/56) (Top Speed 130mph) Regina Chain (116 Link) Custom Tank Dent & Body Work Custom Machined Solid Stock Steel Axle 2 1/2" Longer Each Side Custom Machined Delrin Spools / Axle Sliders PERFORMANCE: HoHey Designs GSXR 1000 Steering Damper Mod Speedo Healer - Accurate On Dynojet Dyno @ 130mph Brembo Radial Master Front Brake CRG Roll-A-Click (Black Anodized) Shorty Lever For Front Master Steel Braided Goodridge Lines Front, Rear, And Hand Brake Airbox Flapper Valve Removal Mod Kleen Air Mod / Pair Mod Tee HTEV System Mod (Set To 3k - 7k Rpm Position) K&N Air Filter Custom Shortened Yoshimura Exhaust (12" Total Length) Honda 1000xx GP Shifting Mod APE Cam Tensioner Power Commander PCIII USB Custom PCIII Map (HP) 125.47 (FT-LBS) 61.99 Pirelli Diablo Superbike Racing Slicks (120/70/17 Front - 190/55/17 Rear) Metal Racing Valve Stems Engine Ice Radiator Fluid LOOKS: Aluminum DBB Ends Pro Grips (Black & Grey) Acerbis Diamond Headlight w/ Custom Bracket (Lights On High Beam) CREE MR16 3w 240 Lumen 7800k LED Headlights (x2) Re-wired Instrument Cluster Harness Under Tail Kit - LED With Integrated Blinkers Body Work Sprayed 360* with Line-x Bed Liner Airbox Snorkels Removed Rear Hugger Removed Chain Guard Removed Powder Coated Front & Rear Rims, Crash Cage, Sub Cage Gold Anodized Rear Brake Cap Hi, I'm Pixel 6... and I approved this message. - Pixel - |
Wow, great minds think alike hey haha?! Awesome looking bike man. Making space on the front while keeping it looking clean is one of my larger obstacles to overcome in this build so a picture of your mounting system for the headlight would be greatly appreciated!
That Hoheydesigns site has some pretty good stuff, especially for the triple tree. The DBB mount would hold my digi nicely. Thos look like ProTaper bars flipped upside down on your bike. How do you like the feel of them? Thanks for the picks, good to have another fighter around :D |
