spark plugs
RE: spark plugs
It happens with a bike with miles on it. Surely the tip of the plug was not covered in oil, you mean the threads right? Any bike with some higher mileage is going to get blow by in the cylinder, but the plug should burn most of it off. I wouldnt worry too much about it. You could do a leak down test and see what it says. I doubt it's too bad to worry about.
RE: spark plugs
OH!! [:'(] Well, again, I wouldnt worry too much about it unless when you pulled it out it was absolutely dripping with oil. Again, the center of the plug should be a milky brown and dry, possibly a little gas on there, but normally dry. If it lookes like you dipped it in oil you most likely would know something is wrong, a piston would almost have to be broke for that to happen. Even blow by on the rings wont allow enough oil through that the plug cant burn off. Id put new ones in and go enjoy some corners.
