spark plug change
Old Feb 11, 2005 | 09:26 PM
CivicRacerX7's Avatar
Default spark plug change
having never changed the plugs on my bike I spent the outrageous $8 per plug and got honda NGK's anyways I fouled a plug earlier by giving throttle while the choke was on oooppss!!
anyways I tear the plastic off and the seat and tank to discover the plugs are dman hard to get to. UNable to remove that plastic/rubber divder I basically ripped it out without causing damage. It looks like hell to get it back into place. Is this divider important? Is this the correct method of changing plugs?
I'm changin the plugs now and wanted to see if I need to struggle and get the divider back in befoer I put her back together
someon lemme know I hope I can do wihtout i its a BITCH to get out/in
thx!!!
1994 CBR 900 RR
Old Feb 11, 2005 | 11:54 PM
Tony Mawad's Avatar
Default RE: spark plug change
ORIGINAL: CivicRacerX7
1994 CBR 900 RR
Well, the way I do it is the easiest I think.
I also have a 94.
All you need to do is:
Remove the middle side fairings
pull the boots off the plugs
put in the socket that came in the tool pouch on the spark plug
loosen it with the 8mm or 10mm wrench that also came with the tool pouch
when it is loose & spins easy, put a piece of rubber hose on the plug & twist off
To put them on:
put a rubber hose around the spark plug (it will hold it snugly)
lower that in the spark plug hole & twist
when it seats firm, pull out the hose & tighten with the socket & wrench that came with the tool pouch
put the mid fairings back on
Old Feb 13, 2005 | 02:08 PM
laser20psi's Avatar
i took my plugs out a number of times because i hate ngk's sorry for those ngk lovers out there. I used a regular socket with a flex extension and rachet. then when the plugs were out i pushed the plug boots back in and pulled the plug out easy.
rapidspec
Jan 14, 2015 04:04 PM
MARCD1
Jan 9, 2012 09:49 PM
Stoner
Mar 20, 2011 08:15 PM
Det99cbrf4
Jul 25, 2007 07:45 AM
sixs929
Jun 1, 2006 06:51 PM
