service time :)
Old Sep 9, 2008 | 12:42 AM
l0st1's Avatar
Default service time :)
ok im having my carbs synced tmrw- but what else should i have the mechanic look at while the bike is torn apart
so far im just going to have my carbs synced and swap out the plugs cuz imsure they could use some new ones.
but should i even bother having him check anything else?
its my dads dealership- so im not getting charged much for the service-
so what all else should i have gone through?
Old Sep 9, 2008 | 02:20 AM
DukeCBR's Avatar
Default RE: service time :)
Hey there, welcome to the forum. Well obviously you would have to change the oil and air filter as well as your oil-filter. Check the water level of your cooling system. Clean and Wax up your chain and check the tension. Check air pressure of your tyres and run a spot check for irregular wear. Run voltmeter checks of your electrical system as well to make sure that the correct volts are getting kicked out.
Basically do a thorough check as far as you can go. Cannot skimp on the safety of your ride.
Old Sep 9, 2008 | 03:10 AM
dinez74's Avatar
^^ Topic closed.
Old Sep 9, 2008 | 03:22 AM
DukeCBR's Avatar
Old Sep 9, 2008 | 07:10 PM
MT Wallet's Avatar
Check valves and sparkplugs?
Old Sep 10, 2008 | 01:16 PM
l0st1's Avatar
ok thanks guys-
corcoraj
Sep 15, 2009 03:23 PM
Pauly_V
Dec 11, 2008 07:10 PM
Phillyf4i
Dec 1, 2008 09:42 PM
VP
Sep 14, 2007 09:56 PM
DJ SLYKE
Jun 1, 2006 11:45 PM
