REAR SEAT FAIRING 93' to 96'?
Hi,
Just purchased a 93' 900rr and thinking of replacing the rear seat faring with a 96' or there abouts.
I was wondering if these parts would bolt straight on and if so would i have to change the rear tail light.
Any info would be appreciated.
Cheers
Cheers
The rear light is the same but that is all!!
The side panels will bolt on to the front mounts ok but the rears will not line up. You will have to cut the boss off of the subframe and bond/weld it back on to line up with the ~'96 fairings. The later fairings have a wider profile so you will need the later tail light surround. I think the upper panel with the pillion seat lock on is interchangeable. Both seats should be fine although when I did this ('93 - '96) the pillion seat was a bit high and left a gap between it and the fairing.
