quick qeustion
RE: quick qeustion
I'm 100% certain that all of the rear wheels are the same. What I'm not 100% on are the front. I believe only 98-99 will work with one another.I think the '98-'99 brake rotors wont fit right on the earlier wheels but like I said, I'm not 100% on that. Whenever I needed a wheel, I always looked for a '98-'99 and never tried to fit an earlier rim. As for other interchangeability, the '93-'94 front has a provision for a speedometer drive so it may work on a later model but would look a little funny on the right side.
RE: quick qeustion
And I know for sure the forks were placed wider apart in the clamps, so presumably the axle is longer and the spacers are differently sized as well. Front calipers don't mount the same as earlier years either. If you're looking for front wheels, save some trouble and stick with the bike you have: 93-94...95-97...98-99.
Rear wheels, you're golden, though very slightly different sized spacers came with the newer swingarms...so try to get an axle and spacer set from matching years...
