On, OFF and RESERVE
Old Jul 21, 2008 | 03:04 PM
archie's Avatar
Default On, OFF and RESERVE
cant figure this out, the petcock whats up down and left???
had the starter solenoid replaced on my bike and not sure if my mechanic had to take the tank off for this.
reason being i rode my bike home, to work and back home when it then stalled on me and when i gave it gas it sputtered out.
pretty sure that it was in the up position when i got it back but i think down is ON correct??
Old Jul 21, 2008 | 03:15 PM
Jeff1980's Avatar
Default RE: On, OFF and RESERVE
Up is reserve, left is off, down is on.
Old Jul 21, 2008 | 03:17 PM
archie's Avatar
that goes for all hondas? i have a 94 cbr900
Old Jul 21, 2008 | 03:19 PM
burk3385's Avatar
April 2012 Ride of the Month
Not sure if its the same for all hondas but my F2 was like that and my 97 900 is like that. The long end up is reserve, down is on and left is off
Old Jul 21, 2008 | 03:52 PM
rons93rr's Avatar
i'm pretty sure he had to remove your tank. it probly got bumped to the reserve position, though most mechanics would shut it off (when taking it off) and then after installing would put it in theon position.some times people forget i guess, that must of sucked.
always check to make sure it is in the on position even after a fill up, it's a good habit to get in to.
Old Jul 21, 2008 | 06:54 PM
archie's Avatar
also, can a bad battery cause the bike to stall and stutter when reved?
Old Jul 21, 2008 | 06:57 PM
archie's Avatar
ORIGINAL: rons93rr
Also for good habit, is it ok to just ride with the tank on reserve all the time?
Old Jul 21, 2008 | 07:07 PM
rons93rr's Avatar
ORIGINAL: archie
ORIGINAL: rons93rr
YOU SO FUNNY HA, HA (NOT)
Old Jul 21, 2008 | 07:15 PM
archie's Avatar
ORIGINAL: rons93rr
ORIGINAL: archie
ORIGINAL: rons93rr
thats why im askinnnnnnngggg i have no idea? Assume that its bad?!? Last bike had a gas guage, this one doesnt so i was trying to just be safe than run out of gas again
Old Jul 21, 2008 | 08:23 PM
rons93rr's Avatar
arrow streight down(on position), arrow streight accross(off position) & arrow streight up (reserve position).
you always waunt to keep it set to the on position so when your fuel gets low you switch to reserve so you can make it to a gas station. if you keep it on reserve you will be pushing your bike to a gas station. ok?
