newb to the forum with a real tricky problem (long)
Just a quick update- tested fuel flow, all is good there. Sync'd carbs, no change there. Put a thermometer on the headers, #4 is def. running cooler than the other 3. Pulled that carb back apart, checked and recleaned everything top to bottom on it and all seems good. Changed coil and wire for #4 out with a known good one. AND THE THING STILL RUNS LIKE CRAP!!!! I need help, badly, I'm about to lose my mind with this stupid bike. What the heck am I overlooking??? My buddy that runs a bike repair shop and helped me sync the carbs is as baffled as I am. I gotta be missing something. I'm not above considering any idea or suggestion at this point.
Thanks
Ben
Thanks
Ben
I just wanted to update yall, I finally got it running right! I think it was a bad coil/ #4 wire. I had tried a different set of coils off of ebay, and had the same problem. I than thought maybe I'd take my old 2-3 coil and use it as a 1-4 since I know it worked, and I also substituted the #4 wire for my old #2 wire since I knew it also worked. At the same time I put a stock air filter in it instead of the k&n, but I really think it was the coil/wire that fixed ended up fixing it. Either way, it runs superb now and I couldn't be more excited! Too bad it's been raining nonstop here in Indiana
Anyhow thanks for your input- ride safe!
Ben
Ben
