Need rear axle measurements - length and diameter
Old Apr 4, 2022 | 07:47 AM
chobes's Avatar
Default Need rear axle measurements - length and diameter
Does anybody have a spare axle that they can measure? Or width of swing arm, outside to outside? Might be picking up an RR, need axle or a steel rod to roll it for transport...
Old Apr 5, 2022 | 05:12 AM
The bearings on a 1998 CBR900RR rear wheel are 6204UU's. Their inner diameter is 20mm. Something 3/4" in diameter would be able to fit temporarily. Not sure what year you're referring to.
Old Apr 5, 2022 | 07:15 AM
chobes's Avatar
Thanks. I picked up the bike yesterday, will post a couple of pics here, or start a new thread, depending on what I'm able to get sorted out over the next few days. Original plan was to swap 900 into F2/F3 frame, as I've wanted to do that swap for 20+ years. The RR is cleaner than I thought, so if I'm able to get the replacement title I might just restore the 900.
Old Apr 6, 2022 | 08:53 PM
chobes's Avatar
Does anybody happen to know what year wiring harnesses are compatible on the 900RR? Diving into the bike and can see that the harness is chopped up pretty bad, would rather just replace it. This is a '94.
Old Apr 6, 2022 | 10:53 PM
1993 and 1994 use the same harness.
Old Apr 11, 2022 | 10:41 PM
chobes's Avatar
Thanks, I've some parts coming in, need to find a manual for a '94 so I can dive into it. Is there a link to a '94 PDF manual somewhere out there that anybody knows of? (I've found '96 and newer only)
Old Apr 12, 2022 | 06:02 AM
https://www.manualslib.com/manual/12...-Cbr900rr.html
Old Apr 12, 2022 | 11:00 AM
chobes's Avatar
I found that one also, but it's for later years...
Old Apr 12, 2022 | 05:16 PM
No I don't think so. It says it was printed in 1995, which would make it for the 1993-1995 900RR models. They are the same.
Old Apr 13, 2022 | 12:18 AM
chobes's Avatar
I thought that also, but it appears Honda dates their manuals for future years, just like the bikes. Appears to be manual for 96 and later as it has the speed sensor on the front sprocket. It's going to work for me though, as someone before me has swapped wiring harness and front end over to 96-97, will be fun to sort out the mysteries ahead...
