Need help with Regulator Wiring.
Old Jul 30, 2011 | 11:37 PM
Paranoia's Avatar
Exclamation Need help with Regulator Wiring.
1994 CBR 900rr
Ok, so I need a little help with regulator wiring. I have a good idea where everything needs to be wired to, but keep getting sparks on battery when connecting because I have a short somewhere. Any help would be appreciated. Here is what I have so far.
Slightly different regulator, but same idea.
Red circle indicates area of need.
Red circle indicating area that I need help with.
Ok, so say the three prongs are on bottom and two on top. I have one Red/White cable connected to top left. Im not quite sure where the green cable goes. Either the other prong on the top, or the prong just above the Red/White. Than we have 3 yellow cables that go the the rest. If someone can check a manual or cable diagram, that would be awesome. Thanks so much.
Old Jul 31, 2011 | 04:05 AM
MadHattr059's Avatar
Can't swear to the 900, but the 98F3 harness has 3 yellow wires, these go to the stator. Doesn't matter what order they are hooked up in.
The red/white is the positive connection and the green is negative connection
to the battery. The R/R you have should be marked and/or have documentation
showing what each terminal is for.
My original connector shows the 3 stator wires on terminals across the TOP
row (next to the release catch) and the red/white on the bottom/left, green bottom/right with the bottom/cntr empty. (this is facing the R/R in the same orientation shown the photo, NOT the illustration).
Here's a photo of my old one with the connector.
Ern
Old Jul 31, 2011 | 03:03 PM
Paranoia's Avatar
That's exactly what I need. Looks like you have the same one that I do. (Was replaced by last owner.) That helps me out SO much! Thanks a bunch.
Old Dec 14, 2020 | 02:55 AM
Jonh Steady's Avatar
If stil for repair got same problem but took pictures before cutting hire
Paranoia
Aug 29, 2011 02:16 PM
mugball
Jun 15, 2011 12:00 AM
corwine123
Oct 22, 2009 11:12 PM
GeorgePBurdell
Jul 22, 2009 11:52 PM
gtrude
Aug 4, 2006 02:32 PM
