need help asap
Old 06-27-2011 | 07:12 PM
diovol's Avatar
Default need help asap
Hi
So i have a 1998 cbr 900rr and a bunch of parts lying around to adapt a rc51 front end. well i thought i had everything i needed but it turns out my parts are all messed up. I know I have the rc51 forks the top triple from an cbr 954 and what i thought was a lower triple from an sp1 but the bearings dont work( from the 954) on the lower part of the stem... anyways im just looking to find out what lower i need in order to make this all work....
thanks
Old 07-04-2011 | 10:16 PM
exciter900rr's Avatar
just a shot in the dark here, but the sp1 top bearing is the same as the 900rr as far as I can tell from the numbers- (I own a 900rr, and had an sp1 apart here) I also would look closely at the space between the races on both bikes.
uppers are the same for sp-1 and 98rr- 91015-KT8-005
the lower for the 98 900rr is 91016-KT8-005
whereas the lower for the sp-1 is 91016-MR7-003
What that tells me is that you might have to press out the stem from the lower triple, and use the 900's stem-
I'll be checking in to see how this goes for you- I'm also interested in doing this-
demon87
F4i - Wanted
02-27-2013 01:24 AM
Tomonfiya
11-14-2009 09:14 PM
rozzzy
01-22-2009 03:10 PM
maximus3
10-27-2006 11:42 AM
Quick Reply: need help asap
