Need Help Again
Old May 10, 2005 | 01:47 AM
sgwkiip's Avatar
Default Need Help Again
bike starts up fine, i was riding and all of a sudden it started doing it, sounds like a v-twin bike, any suggestion, i changed the spark plugs but i dont know what it could be now?
Old May 10, 2005 | 10:52 PM
sgwkiip's Avatar
Default RE: Need Help Again
well i put carb cleaner in the carbs and the bike started up and ran fine, but then after a little bit i took it out, and then when i went to get on the gas it was kinda like sputtering, any one know if the carbs should be cleaned out? o and the air fiter was basically falling apart when i toomk it out and 1/4 of it was missing, so any feedback will be helpful
Old May 11, 2005 | 01:27 AM
fastdaddy245's Avatar
Sounds like your carbs sucked up some of your air filter pieces. I reccomend taking to a shop and having the carbs disassembled and cleaned.
Old May 11, 2005 | 01:46 AM
sgwkiip's Avatar
ya thats what im gunna do, any one know how mcuh it would cost?
Old May 11, 2005 | 04:18 AM
sirlimpzalot's Avatar
It depends on where you take it..I believe that most shops charge about 3 hours for a complete carb cleaning..so what ever the local labor rate times 3 hours...that is what we quote and if it only takes 2 hours then that is what we charge (this is for taking the carbs out of the bike and cleaning, adjusting, and reinstalling the tank, ect...)
Old May 11, 2005 | 09:35 AM
sgwkiip's Avatar
do you think its the carbs that are doing it? cause i dont wanna do it and then that not be the problom, also the bike was driving fine a week ago, then all of a sudden it happened so i dunno, replys back please
Old May 11, 2005 | 01:39 PM
if your air filter is destroyed...the stuff you put in your tank may have eaten the air filter ( it is a UNI isnt it?? Sounds like a foam filter, the stock one is a paper element) But it sounds like the right track if it was running and you put that stuff in and then discovered a half eaten air filter.
Old May 11, 2005 | 08:39 PM
sgwkiip's Avatar
heres pics of the filter
Old May 12, 2005 | 03:25 AM
Check the " throat" of the junction from the air box to the carb and see if that extra missing foam is plugging the passage..it could be strangling the air flow for that cylinder
