Need Help Again
RE: Need Help Again
well i put carb cleaner in the carbs and the bike started up and ran fine, but then after a little bit i took it out, and then when i went to get on the gas it was kinda like sputtering, any one know if the carbs should be cleaned out? o and the air fiter was basically falling apart when i toomk it out and 1/4 of it was missing, so any feedback will be helpful
RE: Need Help Again
It depends on where you take it..I believe that most shops charge about 3 hours for a complete carb cleaning..so what ever the local labor rate times 3 hours...that is what we quote and if it only takes 2 hours then that is what we charge (this is for taking the carbs out of the bike and cleaning, adjusting, and reinstalling the tank, ect...)
RE: Need Help Again
if your air filter is destroyed...the stuff you put in your tank may have eaten the air filter ( it is a UNI isnt it?? Sounds like a foam filter, the stock one is a paper element) But it sounds like the right track if it was running and you put that stuff in and then discovered a half eaten air filter.
