need clutch assembly
Old Nov 30, 2007 | 08:24 AM
yolio's Avatar
Default need clutch assembly
well, i see the clutch disc, metal disc, outer clutch and everything is bad, the bike run fine but obviously as it must be
so i want change everything if is possible, i found one assembly in ebay but is of 929 01, look the same but in bikebandit i see other number parts
somebody know if fits?
thanks
Old Dec 9, 2007 | 04:35 PM
900rrjunkie's Avatar
Default RE: need clutch assembly
?what year 900 do you have???
Old Dec 10, 2007 | 03:45 AM
yolio's Avatar
1996 but i already buy a clutch assembly of 929 2001, check with dealer and "he say" is the same just the clutch disc is different but i get one complete, outter clutch, plates, discs, springs, everything so it must be a bolt on
Old Dec 10, 2007 | 06:13 PM
No way.. i think your local dealer is a &%#$#@%^..... i have a 97 and the only basket that will fit in it is from 96-97- the 98-99 basket is total different. look at the gear on the back of the basket on older models its a 2 part gear and one gear is kinda off set. on the newer models the gear is solid and the crank gear is 2 gears one off set. the 929 and 954 are smaller then all the 900 that was one way for honda to shave rotating mass and gain horse power. and 93-94-95-96-97 all use 10 clutch plates 98-99 uses 9 plates. im not sure howmany are in the 929 and 954. if you go to RON-AYERS.COM you can see the differance in the clutches
Old Dec 10, 2007 | 07:05 PM
dinez74's Avatar
My 97 model had some problem with the clutches and it was replaced from a 98 model by the mechanic. I'm not sure what all the components was replaced but he even had to replace the cover as well.
Nero
F4i - Wanted
Jul 31, 2011 03:22 PM
willybeamish
Sep 3, 2010 05:48 PM
kymeria
Jan 19, 2008 08:12 PM
