My '93 900RR Project
ORIGINAL: rons93rr
my engine will not run won't even chug when trying to start. the starter just fires.
After I replaced my stator cover, I accidentally pushed the starter motor gear off of its little spindle--so the starter had no chance at all to turn the crank and get things moving. Go ahead, ask me how long it took to figure out what I had done lol. As soon as I put the gear back in place and re-applied the stator cover a little more carefully...bam, fire in the hole.
Hopefully your situation might be this simple...
ORIGINAL: sober
Dude sweet job on the custom turn signals. How did you do that? I wanna do that! HBO please.
1. find the led's make sure they are 12V
2. measure the led's for size and get a drill a smidgen bigger
3. push the led thru the holes where they just stick out and epoxy them in (Maxium 883 is what I use from evercoat)
4. Now sand em down and clear or if it is stock plastics sand them down smooth with some 600, 100, 1500, 2000 and 3000
5. buff em out
6. wire em up you will need to get a resistance ballast or the led's will either tweaker blink bad ot not at all
7. ENJOY
hows that
ORIGINAL: sober
Already been working on it. I am gonna do the rear pegs as well for the rear turn signals. Thanks for the info (resistance ballast). Let me know if you make any of those sweet tails?
Resistance ballest are used because LEDE'suse very little amp draw
cool post some pics I want to see em...
4Ye sI am going to make em $450 gets the part in fiberglass including led light,turn along with the under tail...
and $650 in CF
let me know if you want one
I got the old girl running and what a rush to hear it run.
It is a little cold blooded and I have to change the plugs and oil yet. I have a small leak from a crack in the Impulse cover. I'll change covers when I change the oil.
I'll be getting to work on the fairings this week. You can see that they came from several different bikes. The tank,fender, front end and left mid are green, the tail, right mid,right lower, are purple and black, the left lower is white and so on.
It's came a long way but I see light at the end of the road.
Brian
It's came a long way but I see light at the end of the road.Brian
