Like a million others before-New to wheelies. Can anyone help???
Alright Stunters! I got a question for you? I got my 96 CBR900rr tuned up and runing good (I think)...Can't power wheelie, I tried that till it got old. At about 15-20 mph, Let off the throttle and then opened it up, NOTHING.
I tried Clutch wheelie, and did a LiL. better. At about 15-20 mph I pulled in cluth gave it throttle and then dumped it. Got it up about 2 feet that way.
How much rpm do I have to feed it so that I can get it up, atleast 3-4 feet???
Or is it the bike??? Something wrong with bike??? I think I gave it about 6-7 rpm and it is a heavy bike. I'm ready for your advice and corrective critisizm, Shoot!
the bike you got is a wheelie monster. i responded to a recent thread with a small "how to" for stand up wheelies. whatever wheelie you decide to learn, just remember, small steps or it can be painfully expensive.
""I've done different types of wheelies. Power wheelies are easiest and seem to me, to be the easiest to control, to me anyways.
Center yourself standing on the pegs (front to back and side to side) and "bounce the suspension. do this a couple of times to understand how your bike is going to respond. after youve got your timing down start rebounding the suspension with little blips of the throttle. like said earlier in this post, baby steps. timing the rebound of the suspension and use of the right gear and speed is going to crucial.
also, think about this. if you're standing straight up (12 o'clock) and the bike's in front of you, then your not looping it, LOL
i did standups and never really wanted to go back to sitting on wheelies. ""
try this at about 4500 in second gear and work from there.
Don
![Icon Teeth](https://cbrforum.com/forum/images/smilies/icon_teeth.gif)
Don
if your doing a power wheelie then when u roll off the throttle at 10 -15 mph make sure you shut it off quick and suddenly shift your weight over the front end pushing it down, as its when the suspension is springing back up and you wind it open that gives it that little boost to lift. be warned, it can come up very quick, especially if your not used to opening her up. keep the foot break in mind as this can be a savier if you over do it! good luck and be carefull.
On a lonely back country road I slowly took off and then, at about 10 mph, I twisted the throttle pretty hard in first gear. It initially just took off like a rocket sled and I figured that was all it was going to do. Fun, but I was hoping for a wheelie. Well, at about 6-7k rpm the front end started rapidly rising. I probably only had it one foot off the ground but to me, who had never done a wheelie on a street bike, it felt much higher.
Get lined up on a straight stretch of road, twist that throttle and hang on a few seconds. It should come up for you but don't expect the results to be immediate.
