Help with regulator/rectifier wiring
Hi everyone
So my R/R is TOST....... I have 96 CBR900RR , so I got one on ebay but it is for a 02 F4i the wiring on my R/R 3Y-1G-1 red&white , the one I'm getting has 3Y-2G-2red . OK I can comprehend the 2G that is ground no big deal I can deal that , but what about the 2 reds were do thy go ??????? any body out there don this before please I need advice ,Thank you
Not to dodge your question, but you're replacing your junk R\R with ANOTHER junk R\R. Put it back on eBay, and get yourself a good one form a GSXR or an R6. These will be more obvious on how to wire, as well. Honda makes excellent stuff, but the nonexistent cooling for their R\R's was an epic failure.
I don't, but check this thread, it's loaded with info:
https://cbrforum.com/forum/f2-tech-93/regulator-rectifier-r-r-problem-solved-27739/
Also, have you tried the f4i manual?
You don't need a fan on there, just a good heatsink. The PC fan is going oxidize pretty quickly and stop working in the outdoor weather. The problem is the concave top doesn't allow for a heatsink to be mounted flush. You could try smearing thermal compound in between the R\R and the frame, but that's still not as good as a heatsink.
The Yamaha R6 one is IDENTICAL to the Honda one, except they engineered a massive heatsink for it. Here's mine:
https://cbrforum.com/forum/showthread.php?t=27739
Is that rectifier r/r on your bike from a r6 cuase i just got one on ebay brand new and i wanted to know what wiring you used please help i realy want to ride where did you get the info what colors should i use and what wire goes where
I need to know what colors wirs the r/r got & what coloer wirs your bike got or you can call me if you need more ifo
I live on the east cost by daytona if you give me your phone # , I will walk you thou it its easy
