HELP: PLUGS FOWLING
Old Apr 28, 2005 | 07:31 PM
cbolton69's Avatar
Default HELP: PLUGS FOWLING
do anyone have a problem with there 900rr fowling plugs.... i have a 98 rr and it fowls plugs way to often.... any suggestions
Old Apr 28, 2005 | 07:55 PM
chainstretcher's Avatar
Admin Emeritus & MVN
Default RE: HELP: PLUGS FOWLING
What type of fouling do you have? Oil, carbon, antifreeze? Those are the usual suspects. If it's oil and they foul often then you got oil rings going bad. Antifreeze = head gasket about to blow completely out or head bolts backed out. Carbon = too rich somewhere in the rev band. While it's best to have carbon fouling (too rich) that's often the hardest to correct. A dynotune with a sniffer is sometimes needed.
Old Apr 28, 2005 | 11:36 PM
cbolton69's Avatar
thanks... it is like a carbon build up... thanks for the help
Old Apr 29, 2005 | 09:02 PM
Thor's Avatar
check the choke operation to be fully open. i don't have the problem. do you use a k&n, maybe too much oil. are the plugs uniform in color/fowling. how many miles on them before you remove and see fowling.
x
Old Apr 29, 2005 | 10:44 PM
sirlimpzalot's Avatar
I agree that a overly oiled air filter is just as bad as a dirty airfilter; requiring the carbs to work harder...imagine drinking a fresh thick milkshake and you cannot get it thru the straw...now after it melts it is easier...like a excessively oiled air filter and a properly oiled air filter..get it?? or the choke could cause the same symptoms
Old May 1, 2005 | 04:32 PM
cbolton69's Avatar
thanks for the advice... it is usually only one plug at a time that goes.... i changed them at 10:00 one morning and by 2 or 3 one had already gone...
06 gto
Mar 15, 2011 05:26 PM
iroc_254u
Apr 9, 2008 05:37 AM
95HondaCBRF3
Jun 11, 2007 01:58 PM
tho418len
May 25, 2007 07:50 PM
wood83
Mar 6, 2006 11:49 AM
