HELP!
Old May 17, 2006 | 12:55 AM
djxtreme808's Avatar
Default HELP!
OK now that the bike is fixed. I plan to clock this baby @ The Memorial Day Drags. I need to wire in a safety kill switch. I have one but don't know how to do so. The one I have is open circuit when the lanard is in place and when you pull the clip it is a closed circuit. I think it would work by grounding the ignition. But where do I ground it at the coil or someplace else. And if at the coil which side + or -.
Don't mean to sound dumb but this is new to me.
Please give advice or input.
Thanx Xtreme
Old May 17, 2006 | 05:49 PM
chainstretcher's Avatar
Admin Emeritus & MVN
Default RE: HELP!
Why can't you just wire it into the kill switch already on the bike?
Old May 17, 2006 | 07:05 PM
Default RE: HELP!
kill switch on the bike is a normally closed switch then when the switch is pushed it breaks the circuit. but i think if i run the switch to a relay when the lanard is pulled it will energize the relay and the relay can break the circuit. I'll try that.
thanx
Old May 30, 2006 | 06:01 PM
Default RE: HELP!
WELL THE BIKE RAN DECENT AT THE DRAG 11.808 @ 123.80 MPH WAS THE QUICKEST TIME. THAT WAS WITH PULLING OUT AT LOW RPM. COULDN'T KEEP THE FRONT END DOWN AT HIGHER RPM SO HAD TO BABY IT OFF THE LINE. O AND THE KILL SWITCH WORKED WITH THE RELAY.
THANX
