HELP!
OK now that the bike is fixed. I plan to clock this baby @ The Memorial Day Drags. I need to wire in a safety kill switch. I have one but don't know how to do so. The one I have is open circuit when the lanard is in place and when you pull the clip it is a closed circuit. I think it would work by grounding the ignition. But where do I ground it at the coil or someplace else. And if at the coil which side + or -.
Don't mean to sound dumb but this is new to me.
Please give advice or input.
Thanx Xtreme
Thanx Xtreme
kill switch on the bike is a normally closed switch then when the switch is pushed it breaks the circuit. but i think if i run the switch to a relay when the lanard is pulled it will energize the relay and the relay can break the circuit. I'll try that.
thanx
thanx
WELL THE BIKE RAN DECENT AT THE DRAG 11.808 @ 123.80 MPH WAS THE QUICKEST TIME. THAT WAS WITH PULLING OUT AT LOW RPM. COULDN'T KEEP THE FRONT END DOWN AT HIGHER RPM SO HAD TO BABY IT OFF THE LINE. O AND THE KILL SWITCH WORKED WITH THE RELAY.
THANX
THANX
