Fuel Tank issues!
The 900rr should only have 2 bolts, one front & back of the tank. Check out this site, look up the fuel tank specs should give an idea.
http://www.bikebandit.com/houseofmot...m2070#sch14569
Yea i did forget some years have that dual bolt in the front for the stay, mine doesn't. But even at that, your looking at 3 bolts, should be pretty obvious where they go. Sure you didn't take anything else off while the tank was off?
i have a side question.. sorry, but the hoses under the tank..i seem to only have one for fuel... does the other two nipples need ot have hoses going somewehre on them?
Smaller one is an overflow/drainage line, just run a small hose down & out under the bike. The other is supposed to goto the carbs (i think) still looking into that myself, min isn't hooked up either
whar are the extra hoses down in my 900rr i was cheking the bike and one is from cooling sistem and the other one look it come from the fuel thank they both go all the way down,thanks,im wonder if is normal or need to conect somewhere,is my first bike so.is 1998 900rr thank.
