fuel overflow
Old May 26, 2008 | 08:30 AM
tcarino's Avatar
Default fuel overflow
Hello,
I have a 93 900RR. The bike is hard to start. I can get it to start, but I have to hold the throttle 1/4 of the way with the choke on. I do notice there is fuel coming out of what I assume is the "overflow". Does anyone know what I can do to get it to idle on it's own and not have fuel coming out of the "overflow"? There was a bit of old gas in the tank, and I've filled it with fresh 93 octane gas. The bike has been sitting over winter and now trying to get it going again.
Thank You!
Tom
Old May 26, 2008 | 08:56 PM
sas1810's Avatar
Default RE: fuel overflow
if the bike has been standing and the fuel was stale to smell it sounds very much like the float chambers have stuck and allowing too much fuel through. looks like a job of removing the carb bowls and cleaning them out. there was a post in the "HOW TO" section on how to clean and check these things out. hope this helps you out.
Old May 27, 2008 | 01:48 PM
stynkmonkey's Avatar
The easier and cheapest thing to try first is to run about 5 ounces of Sea Foam through it. If that doesn't work then sas1810's advice takes over. Sea Foam is a miracle cure. 7-8 bucks at almost any autoparts store.
Old May 27, 2008 | 06:13 PM
900FighterRR's Avatar
definetely stuck floats or clogged jets. That "overflow" is actually the vent and no fuel is ever supposed to come out of it. So pull you carbs and give them a good cleaning with carb cleaner and make sure all the floats are operating smootly.
Old May 27, 2008 | 10:54 PM
Ghusar's Avatar
I love seafoam...
speedyf4i
Apr 7, 2019 04:40 PM
tamahda
Apr 12, 2014 02:36 PM
Mulkxican88
Nov 14, 2013 05:23 PM
MiloshMobile
Oct 15, 2013 09:22 PM
d4v
Jun 24, 2013 02:58 PM
