engine spacers
engine spacers
i have a 1999 900rr and was wondering if there are rubber spacers between the frame and engine cause when i bought the bike it had been a stunt bike and the guy didnt put the bolts back in after he took off the stunt cage and why would the neutral light stay on when im in gear
RE: engine spacers
That I'am aware of there is no rubber between the frame and engine. As for your neutral light, it is ground activated so disconect the wire from the sender to check the sender, it should shut of. If the light shuts of when you dissconect it the sender is bad, if it dos'nt there is a risistence in the wire somewhere. The sender is located right below the engine sprocket cover. Johnny
RE: engine spacers
aluminumspacers, and yes you need them. i forget, but i think there's only one (right side). go to www.ronayers.com
