Engine problem - What to try next?
#21
Morning , sorry about the PM , wondered why I dont get as many messages , think I have sorted that now, as for the slides , I think they are working as they should ,wouldn't need them for Idling,when you cleaned the carbs did you split them and re-assemble, they can be a pig to get back together ( I know), not knowing the history of the bike , have you done a compression test, also if the Spark plugs get wet it will never start, how do they look, I'm sure we will get to the bottom of this
#22
Thanks. Subjectively, that's pretty much what I've observed. (I knew they'd be damped as they descended closed, but I have no frame of reference with regard to how much resistance there should be to raise them.)
Back to fuel... would you know what this feeds?
I can blow through it (although it's fairly restrictive), and I hear the air quietly exit elsewhere, but can't locate its destination... perhaps the fuel enrichment circuit? Trying to determine if it's clogged or if the restriction is normal.
Thanks for all your help & suggestions!
#24
Ah, thanks.. I figured that's probably what it was. As to carb cleaning, yes, I split them, stripped them completely, soaked the body and metal parts in carb cleaning fluid. Reassembly wasn't too bad until it came to getting the little springs between each carb back in place. Then I began wondering if converting to fuel injection was an option.
Have not done a compression test, nor looked at plugs yet. Failing to resolve the problem by addressing the induction system, I'll expand diagnostics to those (or switch to bicycles.)
#25
Think it's part of the fun ,trying to get the bike going , frustrating too but a sense of achievement when its done, did you bench sync the carbs as there is a good piece in chapter 6 of how to set the butterfly's and to have the butterfly the right side of the idle bypass holes in the venturi
#26
I bought a CarbSync Pro and did a proper sync. The really odd thing is, after cleaning/reassembling/syncing, engine *seemed* to run well (responded to throttle, etc.) I was in the process of completing its resurrection which lasted another month or so after the sync. Got the tank back on and last body panel fitted, started it, and, back to the off idle bog/quitting.
I did enjoy the refurbishment/upgrade process (new hoses, brake lines, R/R, LED lights, etc.) when it was pouring outside. But now, riding weather has arrived, and I'm anxious for the tedious fiddling to end.
#27
