dynatc 2000
Old Aug 18, 2012 | 05:25 PM
Trevor Bredereck's Avatar
Default dynatc 2000
So is it worth 400+dollars to use this ignition system or would it be smart to just use their H.O coils and wires it sure would be less about 300 less and what I don't get the box with the Rev limiter and the bike now has a+4 rotor Wichita I would need to replace for the magnetic rotor any ideas
Old Aug 18, 2012 | 05:41 PM
Default jet kit question
I have a pretty much stock bike its UN molested gem 45k on bike. Second owner nothing cut or chopped. I put on a new D&Scull system and not sure Wich way to go with the jets I k ow I don't want to cut up the air box so from what I have learns it looks like dynajet has a stage2 any ideas would help
Old Aug 18, 2012 | 05:44 PM
Originally Posted by Trevor Bredereck
I have a pretty much stock bike its UN molested gem 45k on bike. Second owner nothing cut or chopped. I put on a new D&d full system and not sure Wich way to go with the jets I k ow I don't want to cut up the air box so from what I have learns it looks like dynajet has a stage2 any ideas would help
Damn spell check its supposed to read full D&D SYS
Old Aug 18, 2012 | 05:58 PM
zaqwert6's Avatar
Nov 2011 ROTM
I wouldn't change anything on the ignition system unless you needed to change something on the ignition system.
The Dyna is a fine unit but its not a cheap item only to gain some minor adjustability.
For a full exahaust system you going to need a full jet kit.
Stock air box is fine, but you'll need larger main jets and a set of adjustable needles.
Modification of the airbox generally results in a compromise of some ridability.
pimpax56
May 1, 2009 10:35 PM
jonorth
Dec 6, 2008 05:28 PM
toc12003
Aug 15, 2006 03:07 AM
