? for Crazyhorse
Old Mar 8, 2008 | 05:30 PM
crazyhorse95gt's Avatar
Default RE: ? for Crazyhorse
^Nicely put^ What I would have said.
Old Mar 14, 2008 | 06:42 PM
stynkmonkey's Avatar
OK so basically these are the steps, let me know if I miss something:
1. take off the old CCT, (obviously)
2. put the new one on (with the new gasket)
3. hand tighten till it's snug
4. put a wrench on it and start the motor
5. listen and tighten till the chain noise stops
6. go about 1/4 turn tighter
7. Tighten nut
8. Lock it down with blue locktite
9. Breathe
Old Mar 14, 2008 | 08:16 PM
slimmyslim1420's Avatar
Yep. Thats pretty much it. Thats what I did and my bike is running great now. No moreirritating noise! Make sure you scrape off all the old gasket to though. I put a rag in the hole while I did that so the pieces didn't fall inside the motor.
Old Mar 14, 2008 | 09:42 PM
Ok I might get my new cct on this week.
Old Mar 15, 2008 | 01:12 AM
Just let me know if you have any problems and I will try to help as much as I can.
Old Apr 23, 2008 | 04:49 PM
I want to make sure I am hearing the right noise and, not having another 900 around to compare, I don't really know what's normal and what's not.
So, what I am hearing is sort of a chain type rattle noise (or like marbles in the engine) like I've read in so many CCT problem threads. Since the engine is making it's own noises it's hard to pinpoint where the rattle is coming from. I noticed that If I hold in the clutch lever just a tiny bit (just enough to take up the slack, about 3-5 mm) it seems to go away. I also hear the valves knocking some when it's cold but goes away after it warms up (which I assume is normal since it's cold) and sometimes under acceleration It sounds like the valves are knocking a tiny bit. It's not like these are way noticeable I just know my bike's noises. Does that sound about right for the cctl?
Old Apr 23, 2008 | 08:41 PM
sas1810's Avatar
Hi Stynk. j had the same problem with the clutch rattle. goes away when revving up or when holding lever in? i found it was the springs in the actual basket where weak. this was on a 94 with 26K. picked a new complete unit up from eBay and it solved the problem. luckily this unit had new plates and friction discs as well. not a bad deal for $50 lol. check your idle as well. see if it is right or a bit low. hoing upanother 100 or so may take the rattle away.
hope this helps.
Old Apr 23, 2008 | 10:29 PM
Ghusar's Avatar
I have a factory stock CCT for a 900 I replaced with a new APE and I tightened it until the sound went away and the 1/8 more...but the old one was good
Old Apr 23, 2008 | 10:59 PM
ORIGINAL: stynkmonkey
My cct noise also went away when I pushed in the clutch. And it would make the noise when cold as well.
Old Apr 23, 2008 | 11:02 PM
Ghusar's Avatar
It sounds like it running lean
Ok is the noise there at start up and under load only?
