Coolant mix with oil, what can go wrong?
Old Jan 11, 2026 | 02:40 PM
Yuta's Avatar
Default Coolant mix with oil, what can go wrong?
This is an old project. I bought an used engine online 5 years ago and went abroad. The engine seems to be in good compression and fires with carb cleaner.
Today I made a fuel reservior which feed fuel directly to carburettor. It started and kept running. Then I started adding coolant through radiator cap while motor was running. I kept pouring 2 gallons of coolant and started wondering why it took so much coolant. I started look online and found out this is way too much coolant. The engine kept running and then the overflow nipple on the valve cover started to spit out oil-coolant mixture... That kinda explains why... So the coolant I added from radiator cap went into the engine and mixed with oil.... The whole time the temp gague didn't move at all, and I touched radiator, it was cold the whole time.
I stopped engine and unplugged the radiator hose, the coolant from the hose is clean, non-contaminated. The tempeature of the coolant is slight warm...
What could be the odds?
Head gasket? Cracked block/head? That don't happen too much on a motorcycle, right?
A bad oil cooler? Oil cooler seems to be a solid compoent, does this happen often?
A bad water pump? The impeller shaft seal is bad and allow coolant to enter???
burningmetalmaniac
Aug 23, 2011 10:37 PM
live4liftin
Mar 23, 2010 10:21 AM
colleenhixx
May 19, 2009 12:28 AM
88_F
Sep 3, 2007 12:07 PM
Err
Sep 9, 2006 02:29 PM
