Choke Won't Stay On
So the first little quirk I’ve noticed with my 1 day old bike is the choke lever won't stay up. I pull it up and it slowly falls back down in about 5 seconds. I can hold it up in place but I’m sure that will get old real fast so does anyone know what the problem might be? By the way its a 96 900, thanks.
MIne is the same way, it almost seems that rubber that should be holding it in place is old and doesn't grip it hard enough. I don't use chock anyway, I just keep the revs at 3k or so for about minute and it idles on it's own after that.
on my 98, under the **** that you pull up is a rubber cap like thing that the rod goes through. if you turn that rubber cap it is threaded and the more you tighten it the more friction it applys to the rod making the **** stay up. that is how it works on my 98 im not sure if the older ones are like that or not. good luck, monsy.
