Cbr954rr front end on 96 900
Old Apr 7, 2024 | 02:45 AM
26george's Avatar
Default Cbr954rr front end on 96 900
Hi I have got a 954 complet front end with forks ,brakes wheels and iwould like to mout it on my 96 900 is it plug and play job ?
Old Apr 7, 2024 | 05:38 AM
Welcome to the forum.
Personally not sure, but one of the more informed members will be along shortly with some advice.
Old Apr 10, 2024 | 02:31 PM
dannoxyz's Avatar
Not direct swap:
1. have to press out steerer-tube from 954RR's lower fork-clamp and press in tube from 900RR
2. will loose speedo function as newer ones are electronic driven from VSS in transmission instead of mechanical cable from front wheel
Old Apr 10, 2024 | 02:53 PM
26george's Avatar
Originally Posted by dannoxyz
Not direct swap:
1 I have upper and lower fork klamp from 954rr but I didnt see any steer tube
2 Mine 900 sc33 from 96 has speedo cable in transmission above the small sprochet not at front wheel
Old Apr 10, 2024 | 04:07 PM
dannoxyz's Avatar
This is part you need to press out of 900RR lower fork-clamp and press into 954RR's fork-clamp.
Old Apr 10, 2024 | 11:19 PM
Ed Harris's Avatar
Is it possible to adapt by changing the bearings for one’s with different internal diameter?
Hm, not if the length of the shaft is different!
Need a big press - a professional job?
Ops, rambling again :-)
Old Apr 12, 2024 | 04:51 AM
dannoxyz's Avatar
steerer tube is different diameters
head-tube on frame different diameters.
Not sure you'll be able to find smaller bearings that'll fit inside 900RR's head-tube and over larger 954RR's steerer-tube.
Old Apr 12, 2024 | 05:02 AM
Ed Harris's Avatar
Thanks, that makes huge sense.
Old Aug 4, 2024 | 08:18 PM
Kenmac's Avatar
Hi, I've just fitted a.954 front end onto my 96 blade, it was a exact fit even the bearings fitted, no modifications whatever.
tarr
May 1, 2012 01:43 PM
Bazman
Jan 1, 2010 02:01 PM
memphis tn
Jul 26, 2009 04:26 PM
ocrider26
Apr 29, 2007 05:34 AM
