Cbr900rr 1998-2000 with cbr1000rr rear wheel
Old Sep 10, 2023 | 04:05 PM
Olstorparn's Avatar
Default Cbr900rr 1998-2000 with cbr1000rr rear wheel
Hi guys!
im gonna do a custom project and will be using a cbr900rr 98-00 swingarm. is it possible to put on a cbr1000rr 04-08 rear wheel without to much or none modifications and make it work with chain / rear brake?
thank you
Old Sep 10, 2023 | 10:34 PM
dannoxyz's Avatar
You'd have to replace all bearings and spacers as axle-diameter on 1KR is larger.
And need to make custom spacers as outer-width at hub is wider as well.
You'd have to measure both wheels and calculate differences and make necessary spacers to place sprocket, brake-disc and brake-caliper in proper locations.
Here's picture I came up with for different swap.
Easier to just use CBR1000RR swingarm with matching wheel you want.
Old Sep 11, 2023 | 02:43 PM
Olstorparn's Avatar
thanks for ypur quick reply. Seems to be alot of work to make it fit then. I will have a look on other options for lighter wheels that could fit
Old Sep 11, 2023 | 05:35 PM
dannoxyz's Avatar
The lightest wheels are CBR600RR, couple lbs lighter than 1KRR. And they come in 16x5.5" to use common tyre sizes.
929trf
Aug 13, 2011 10:27 AM
tri5333
Nov 13, 2009 09:19 AM
blade945
Aug 15, 2009 05:39 AM
