Cbr900rr 1998-2000 with cbr1000rr rear wheel
Hi guys!
im gonna do a custom project and will be using a cbr900rr 98-00 swingarm. is it possible to put on a cbr1000rr 04-08 rear wheel without to much or none modifications and make it work with chain / rear brake?
thank you
thank you
You'd have to replace all bearings and spacers as axle-diameter on 1KR is larger.
And need to make custom spacers as outer-width at hub is wider as well.
You'd have to measure both wheels and calculate differences and make necessary spacers to place sprocket, brake-disc and brake-caliper in proper locations.
Here's picture I came up with for different swap.
Easier to just use CBR1000RR swingarm with matching wheel you want.
