Cbr900rr 1997 full throttle problem
Old Feb 4, 2022 | 08:52 AM
joy's Avatar
joy
Default Cbr900rr 1997 full throttle problem
Hello,
i have a strange probem with my blade: runs good until 5500rpm, then the engine starts stuttering in all gears. When pulling the full throttle in idle speed, stuttering too. The carbs are totally clean and calibrated, new carbs membranes, vaccum line is good, fuel pet **** works good, valve clearence perfect, engine compression check(perfect) all electrical wires are good, new spark plugs, air filter, air filter box not modified, no air leaks. Plug wires check. So everything is fully checked, but problem is not gone. Everything is stock, except exhaust muffler(it's Bos carbon muffler) I don't have any ideas what's happining.. maybe someone have more ideas?? (sorry for my bad english)
Old Feb 4, 2022 | 11:07 AM
Sounds like it might be the fuel pressure regulator on its way out.
Old Feb 4, 2022 | 11:51 AM
joy's Avatar
joy
Mine doesn't have fuel pressure regulator, originally works on gravity feed🙂
Old Feb 4, 2022 | 11:56 AM
ooppss of course not injected
Old Feb 12, 2022 | 07:49 AM
dvhttn's Avatar
Tank breather partially clogged? Try a run and open the filler cap when it starts to splutter (best not to have too much fuel in the tank at this stage ... :-) ).
Old Feb 13, 2022 | 11:32 AM
joy's Avatar
joy
Hello, thanks! Maybe🤔
I will check tomorrow😊
Daniel Burke
Nov 22, 2017 03:14 AM
HELIGUY02
Sep 25, 2009 05:15 AM
cbr_newbie
Sep 23, 2006 05:27 PM
On_one_wheel
Aug 9, 2006 10:14 AM
Heaton830
Jun 18, 2006 03:14 AM
